System/error logs in the admin interface
Error logs are only accessible on the server; admins without shell access cannot inspect problems.
In a hosted/enterprise setup the functional administrators are not the infrastructure operators; first-level diagnosis (failed channels, integration errors) must be possible from the UI.
The admin interface offers monitoring, but no access to the system/error logs.
Expose system/error logs in the admin interface (read-only viewer).
Ticket#10231017
