Expecting the docker to start and the webgui to come up. Version 3.x comes up without issue
All versions 4.x and up get stuck after the init process, the Nginx container reads ‘starting nginx…’. It’s been this way for a few hours. I’ve started from scratch with mostly default variables set in the compose folder. I’ve changed the data storage locations and added container names, but aside from that, I’ve done nothing different than what I did for 3.x, which runs fine. I’m deploying this through portainer’s template management area. But I’m sure running docker-compose manually on the cli would result in the same behavior.
hey hey! I figured it out… I missed the change of port 80 to 8080. Looks like I’m able to run zammad perfectly on unraid using portainer to input the compose file.
