Hi @SaifNeon. You need to provide more information, otherwise, nobody can help you.
What kind info you need. .
I can explain Scenario. I have installed zammad the proper way everything was working
Unless Once I go to Signup It wont allow user to sign up. It Generates Error Code and 500 Error.
But If I go look into Users in Admin mode of zammad I can see they have ben created
Please provide some error messages (production.log
Give me time I will provide u that too
Can you let me know for path of production log I could find it
https://i.imgur.com/KDvrzB1.png Here u can see user has been created but on other side it gives error
I am trying to find production log but there isnt any file regarding that in var folder https://i.imgur.com/DT3jUlW.png
This is Error in Production log https://i.imgur.com/RTNgQyk.png
It’s written in the log file. Your setup is not fully correct, you’ve configured sendmail
but it seems to be not usable at all. This is the issue.
Where I need need to setup sendmail option
Installing sendmail is not part of the Zammad documentation, as it is part of your email setup.
To install sendmail
you’re required to install an MTA like postfix
. The easier way is to setup a SMTP send account for your notification channel and switch it from sendmail to SMTP.
yes by installing postfix and seting up everythng worked up but there is one problem it say email confirmation thing. In actual it isent sending me any kind of Emails to verify account . How that’s possible.
Secondly If that process is time taking how i can removed that from removing that option for my customers
Sorry I do not underatand your question or issue.
I mean once user create an account he get Verify Email option. But on Email side he doesn’t receive any emails
The user verification mail is sent via the notification channel and only triggered if the user uses the registration link on the instances login page. No Email will be send if you or an agent adds the customers account or if the user was created due to an incoming email.
If your criteria fits above, double check the email channel and possibly Email server logs. Possibly junk folder as well.
If I wanted to remove that verification process and directly if user creates an account redirect to Dashboard.
https://i.imgur.com/2A1PIYi.png
OR If its possible to know setting up verification process
That’s not possible and is a safety measure.
I am confused. That’s already implemented.
