theier
November 9, 2020, 8:52am
#1
Used Zammad version: 3.5.0
Used Zammad installation source: package
Operating system: Debian 10
Browser + version: Firefox 78.4.0esr
Having an option to enable SSO authentication in the thrird party application section
Not having an option to enable SSO authentication
initially installed zammad version 3.3
database is migrated to a seperated Server
Updated to latest version via apt
setup kerberos auth as descriped in the latest zammad documentation
I now get this error message when opening /auth/sso:
Our release notes provide the needed hint…
" The SSO functionality now needs to be activated via Admin -> Security -> Third-party Applications -> Authentication via SSO"
If you can’t find the option, your upgrade probably isn’t completed successfull.
Check your migrations.
theier
November 9, 2020, 2:38pm
#3
Thanks for the quick reply. You are right. The migration failed at creating a smime_certificates table and some index. we had to enable innodb_large_prefix and set innodb_default_row_format to dynamic as descriped at:
Used Zammad version: 3.4
Used Zammad installation source: (source, package, …) package
Operating system: Centos7
Database: mariadb 10.1.x
DB Charset: utf8_unicode_ci
rake db:migrate running successfully
throws error Specified key was too long; max key length is 767 bytes: CREATE INDEX `index_smime_certificates_on_modulus` ON `smime_certificates`
updating Zammad with MariaDB as Database
Did someone else had the…
afterwards i deleted smime_certificates and run “zammad run rake db:migrate --trace” and the migration worked.
The option is now available and is working correctly.
Thanks again,
Thomas
system
closed
March 9, 2021, 2:38pm
#4
