- Used Zammad version: 2.3
- Used Zammad installation source: centos repo
- Operating system: centos 7
- Browser + version: multiple
nginx error log:
2018/02/13 09:04:29 [error] 1818#0: *37748 upstream prematurely closed connection while reading response
header from upstream, client: 1.2.3.4, server: XXX, request: "GET /ws HTTP/1.1",
upstream: "http://127.0.0.1:6042/ws", host: "XXX"
nginx config:
upstream zammad-railsserver {
server localhost:3000;
upstream zammad-websocket {
server localhost:6042;
server {
listen 80;
server_name XXX;
set_real_ip_from XXX/16;
set_real_ip_from 127.0.0.1/32;
real_ip_header X-Forwarded-For;
real_ip_recursive on;
root /opt/zammad/public;
client_max_body_size 50M;
expires max;
location /ws {
proxy_http_version 1.1;
proxy_read_timeout 86400;
location / {
proxy_read_timeout 300;
gzip on;
gzip_proxied any;
Is there a option to set a higher log lever or is there any other way to find the error?
