Split RPM / Deb into multiple packages
I would like to see a split in the RPM / Deb Packages to achieve the following:
  • Install a package (e.g. zammad-files) to only install the zammad application (without dependencies).
  • Install a package (e.g zammad) to install the full Zammad Stack (zammad-files, PostgreSQL, Elasticsearch, …)
With this approach it would be easy for everyone get up and running very fast, while experienced users and organisations with dedicated database-/loadbalanncing-servers can profit from an easy to install/easy to update solution. Owncloud is using this very approach (Redirect Notice).
Best regards,
Fabian
we are already working on this :slight_smile:
Best
Mirta
Internal note:
https://github.com/zammad/coordination-technical-debt/issues/319
