This is the production log
[2018-10-02T11:10:36.307739 #1271] INFO – : fetching imap (imap.gmail.com/info@zzzzzz.com port=993,ssl=true,starttls=false,folder=INBOX,keep_on_server=true)
I, [2018-10-02T11:10:38.180580 #1271] INFO – : - no message
I, [2018-10-02T11:10:38.182518 #1271] INFO – : done
I, [2018-10-02T11:10:38.976456 #1271] INFO – : Scheduler running…
I, [2018-10-02T11:10:38.986735 #1271] INFO – : Running job thread for ‘Check Channels’ (Channel.fetch) status is: sleep
I, [2018-10-02T11:10:38.987143 #1271] INFO – : Running job thread for ‘Check streams for Channel’ (Channel.stream) status is: sleep
I, [2018-10-02T11:10:38.987193 #1271] INFO – : Running job thread for ‘Generate Session data’ (Sessions.jobs) status is: sleep
I, [2018-10-02T11:10:38.987232 #1271] INFO – : Running job thread for ‘Process escalation tickets’ (Ticket.process_escalation) status is: sleep
I, [2018-10-02T11:10:38.987287 #1271] INFO – : Running job thread for ‘Import OTRS diff load’ (Import::OTRS.diff_worker) status is: sleep
I, [2018-10-02T11:10:38.987962 #1271] INFO – : Running job thread for ‘Execute jobs’ (Job.run) status is: sleep
I, [2018-10-02T11:10:43.504988 #1271] INFO – : execute Job.run (try_count 0)…
I, [2018-10-02T11:11:08.206581 #1271] INFO – : execute Channel.fetch (try_count 0)…
I, [2018-10-02T11:11:08.208890 #1271] INFO – : fetching imap (imap.gmail.com/info@zzzzzz.com port=993,ssl=true,starttls=false,folder=INBOX,keep_on_server=true)
I, [2018-10-02T11:11:09.963671 #1271] INFO – : - message 1/1
I, [2018-10-02T11:11:18.383228 #1271] INFO – : Process email with msgid ‘<MWHPR22MB0365BB64E10316A0209E4E9CFEE80@MWHPR22MB0365.namprd22.prod.outlook.com>’
I, [2018-10-02T11:11:18.449545 #1271] INFO -
Im received my client email at 10:46 and already read that message from gmail in browser. until 11:10 still there’s no message appear on Zammad, at 11:11 im make that message “mark as unread” and finally appeared on Zammad.
is zammad need unread message to sync email from IMAP?
