HI,
I have a debian 10 with zammad 5.0.3 source installation. I have only one ip address so I need a reverse proxy to be able to use multiple servers. In the past I used nginx but I want to change to haproxy and ssl termination. Every other server in my system seems to run fine, but zammad makes some troubles. It seems to work, but not 100% stable.
Does someone use also haproxy as reverse proxy and can help me with a working configuration?
Thanks,
Christian.
Well… I still need to update to 5.0.3, so I’m not sure if something is different.
Anyway, you can try with this simple version:
frontend lb
mode http
bind your_listening_ip:443 name your_listening_ip:443 tfo ssl crt /etc/ssl/private alpn h2,http/1.1
bind your_listening_ip:80 name your_listening_ip:80
option forwardfor
acl host_zammad hdr(host) -i zammad.url
redirect scheme https code 301 if host_zammad !{ ssl_fc }
http-request add-header X-Forwarded-Proto https if { ssl_fc }
use_backend http_zammad if host_zammad
backend http_zammad
description zammad backend, http
mode http
server zammad_server your_zammad_ip:80 check inter 5000
thank’s for the quick response.
This is more than less the config I have, but it always ends in an: CSRF token verification failed!
If I don’t use SSL Termination, than it works fine, since I added a little bit more timeout for the server.
Any idea?
