Hi ocerecedo,
I’ve setup the same scenario as you and actually have an identical problem. Zammad is able to download the verification email form the Exchange accout to verify the setup (and removes the verification email ) but doesn’t download any unread email from the Inbox.
Have you found any solution for your problem?
Me setup is:
- zammad 2.9 as docker image
- davmail 5.2.0 (latest released version)
Excerpt from the production log:
Successfull verification:
I, INFO -- : execute Channel.fetch (try_count 0)...
I, INFO -- : fetching imap (10.1.8.122/xxxx port=1143,ssl=false,starttls=false,folder=/Posteingang/test,keep_on_server=false)
I, INFO -- : Started GET "/api/v1/channels_email?_=1557245839002" for 10.1.3.253 at 2019-05-07 17:48:45 +0000
I, INFO -- : Processing by ChannelsEmailController#index as JSON
I, INFO -- : Parameters: {"_"=>"1557245839002"}
I, INFO -- : Completed 200 OK in 55ms (Views: 5.6ms | ActiveRecord: 10.1ms)
I, INFO -- : - message 1/1
I, INFO -- : done
I, INFO -- : verify mode, fetch no emails #13797584534
I, INFO -- : - verify email #13797584534 found
I, INFO -- : Completed 200 OK in 16877ms (Views: 0.4ms | ActiveRecord: 9.9ms)
I, INFO -- : Started GET "/api/v1/channels_email?_=1557245839003" for 10.1.3.253 at 2019-05-07 17:48:50 +0000
I, INFO -- : Parameters: {"_"=>"1557245839003"}
I, INFO -- : Completed 200 OK in 61ms (Views: 6.2ms | ActiveRecord: 11.1ms)
I, INFO -- : Scheduler running...
Inbox actual contains two messages - not one as stated within the logfile
I, INFO -- : fetching imap (10.1.8.122/xxxxx port=1143,ssl=false,starttls=false,folder=/Posteingang/test,keep_on_server=false)
I, INFO -- : done
I, INFO -- : done
Regards
Martin
