Used Zammad version: 2.9.0
Used Zammad installation source: Deb/Ubuntu repository
Operating system: Ubuntu 18.04 LTS
Browser + version: Safari 12.0.3
Hey everyone,
I’m new to Zammad and am looking for some assistance to actually get it up and running.
The installation went as expected and Zammad itself seems to be running, however, it cannot be reached from the browser. I’m using Apache2 and changed the zammad.conf as follows:
<VirtualHost *:80>
ServerName zammad.mydomain.de;
## don't loose time with IP address lookups
HostnameLookups Off
## needed for named virtual hosts
UseCanonicalName Off
## configures the footer on server-generated documents
ServerSignature Off
ProxyRequests Off
ProxyPreserveHost On
<Proxy 127.0.0.1:3000>
Require local
</Proxy>
ProxyPass /assets !
ProxyPass /favicon.ico !
ProxyPass /robots.txt !
ProxyPass /ws ws://127.0.0.1:6042/
ProxyPass / http://127.0.0.1:3000/
DocumentRoot "/opt/zammad/public"
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory "/opt/zammad/public">
Require all granted
</Directory>
</VirtualHost>
I restarted Apache, Zammad and, actually, the whole server and still am being shown the Web Server’s default page. Is there anything obvious I’m missing?
Hi Joey,
what default configuration do you mean? The Zammad installer created a zammed.conf in /etc/apache2/sites-enabled – I edited that file by changing the "localhost“ entry to a subdomain on my server. And then enabled it, yep.
<VirtualHost *:443>
SSLEngine on
SSLProtocol all -SSLv2 -SSLv3
SSLCipherSuite EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH
SSLCertificateFile /etc/nginx/ssl/fullchain1.pem
SSLCertificateKeyFile /etc/nginx/ssl/privkey1.pem
#SSLCertificateChainFile /etc/ssl/lets-encrypt-x3-cross-signed.pem
#SSLOpenSSLConfCmd DHParameters /etc/ssl/dhparam.pem
ServerName localhost
HostnameLookups Off
ServerSignature Off
ProxyRequests Off
Require local
</Proxy>
ProxyPass /assets !
# Use settings below if proxying does not work and you receive HTTP-Errror 404
# if you use the settings below, make sure to comment out the above two options
# This may not apply to all systems, applies to openSuse
#ProxyPass /ws ws://127.0.0.1:6042/ "retry=1 acque=3000 timeout=600 keepalive=On"
#ProxyPass / http://127.0.0.1:3000/ "retry=1 acque=3000 timeout=600 keepalive=On"
<Directory />
AllowOverride None
</Directory>
Require all granted
</Directory>
Uh, I think this discussion might have helped me already.
Plesk places Apache site confs in /var/www/vhosts/system/subdomain.domain.tld/conf/httpd.conf
I tried it with your config, @atimias. Now I’m running into a 403 error page. That, however, is something I can handle, I guess.
