I’m just testing for now, once i know how to setup Zammad, i will install a new VM. In the meantime i uninstalled Zammad and reinstalled it, after “Reset Zammad for a fresh start after testing” didnt work at all. I now setup a Company first and after that startet and LDAP Sync. But still no users are mapped to a Company.
How do i need to setup the Company Sync for my LDAP Users? Is there a way to map existing users to a Company?
You need to use environment variables (or as you use a installed package another command). It will then work.
To your question: Currently Zammad does not automatically sync any companies.
What you need to do is to create your companies within Zammad before syncing your users.
Enable domain based allocation for the company, please note that the domains need to be unique for this, E-Mail providers like GMX, Posteo and such will cause wrong allocations.
to sync my LDAP Users with the Company? Do i need to enter their Emailadressdomain (e.g. mycompany.com) or do i need to enter my local LDAP Domainname here (e.g. mycomp.local) ?
Juhu!! Found it, i realy need to enter the Emaildomain here. I dont think that this is very intuitiv, maybe a hint would help. Also a posibility to let the Zammad map users to Company again, after first LDAP Sync. Thank you for your help
