Used Zammad version: Latest
Used Zammad installation type: Package
Operating system: Debian
Upon using HTTP PUT request to create a KB article it receive no error
"error": "Translations kb locale must exist",
"error_human": "Translations kb locale must exist"
curl --location --request POST 'https://____/api/v1/knowledge_bases/1/answers' \
--header 'Authorization: Token token=_____' \
--header 'Content-Type: application/json' \
--data-raw '{"category_id":"1","translations_attributes":[{"title":"test05 api", "id":"","content_attributes":{"body":"test05 api body"}}]}'```
mantas
April 27, 2022, 10:01am
2
@Filippoc it needs kb_locale_id attribute inside of translations_attributes. That locale has to be created on the server beforehand. Even if KB is not translated, there’s still a single translation
It Worked!!
I’ve been trying to have a better understanding of these undocumented API looking at the routing file (zammad/knowledge_base.rb at c1d467aa3de322f2c35ada1d32590f2b1b2397b9 · zammad/zammad · GitHub ) but without much success.
Thanks again!
If i’ll have time to work on a super simple documentation which is the better way to distribute it to the community?
Hey,
contributions to the documentation would help most of the Zammad users in my opinion ( I mean instead of single fractures all over the internet ).
You can find ideas on how we visually built the API docs here:
https://docs.zammad.org/en/latest/api/user.html
Documentation source wise, the relevant files can be found here:
system
Closed
August 25, 2022, 12:05pm
6
