[Solved] Failing Jobs: Failed to run background job #1 ‘BackgroundJobSearchIndex’
Important:
  • Used Zammad version: 2.6
  • Used Zammad installation source: (source, package, …) RPM
  • Operating system: RHEL 7
  • Browser + version: Firefox 63
  • Under monitoring it should display no issues
  • Under monitoring > Current Status it displays:
406 failing background jobs.
Failed to run background job #1 ‘BackgroundJobSearchIndex’ 10 time(s) with 60 attempt(s).
  • Upgrade from Zammad 2.5 > 2.6
I have this morning updated our Zamad server to v2.6, everything went okay except for the LDAP sync flagging an error that was resolved with the help of another earlier post highlighting the same issue.
All that’s left to resolve now is the background jobs failing. Elasticsearch is running fine and I can’t see any other problems but I cannot seem to get the background jobs to begin processing again. I did find a script on another ticket but that either hasn’t made a difference or I don’t know how to run a script under zammad run rails c.
Some help to get this resolved would be much appreciated.
Kind Regards
Sully
Solved it myself. Turns out that after the upgrade the Elasticsearch ingest-attachment plugin had vanished. Once I had reinstalled that and rebuilt the index the issue has now been cleared. Process below for anyone else experiencing the same issue:
sudo bin/elasticsearch-plugin list (to check if it is currently installed, if not next step)
sudo bin/elasticsearch-plugin install ingest-attachment
restart Elasticsearch service
This should cure the issue.
Cheers
Sully
Addition:
For me, it was sometimes necessary to restart the elasticsearch service manually after installing the ingest-attachment, otherwise the rebuilding command would run into an error.
systemctl restart elasticsearch
Hi Charburner, yeah I had to do the same which is why I mentioned about restarting the service in the solved response. The reason I didn’t specify the command is it will differ for someone not on RHEL/CentOS etc so just said to restart the service.
Thanks :slight_smile:
Oops, I totally missed that line :flushed:
