I read the Manual again and found that i forgot to edit the .env File. So i entered a Tag and now Elastic Search seems to run stable, but there are still 30 Backgroud Jobs Failig:
In case you encounter this again - the most probable cause for ElasticSearch restarts would be that you forgot to configure vm.max_map_count=262144. Ensure that this is configured somewhere so that it will survive reboots. I’ve put it into my sysctl.conf:
That should be completely irrelevant. When you don’t set a version, it’ll just always the latest one (which is a bad idea because the latest one might be broken, so therefore it’s recommended to set a version and manually upgrade from time to time). The only reason why not setting a version could break ElasticSearch is if the latest version simply contains a broken ElasticSearch image/container.
But without having looked at the logs it’s of course now impossible to determine the exact cause of the problem
