Follow-up to Email notification delay about 5 hours, CPU Usage 100% , which that thread closed last year. Environment: Debian 9 + Zammad re-install from March 2019
Symptoms
CPU hits 100% regularly.
Emails fail to deliver.
tail /var/log/zammad/production.log indicates failed lock attempts; my system was apparently hung up on some data from 2 months ago.
Solution (as a sudo-based user)
systemctl stop zammad
su - zammad
zammad run rails r “Delayed::Job.delete_all”
curl -XDELETE ‘localhost:9200/zammad_production’
exit
systemctl restart zammad
The actual log file messages would be useful to tell you what’s wrong.
Beside, a zammad run rails r 'Delayed::Job.delete_all' is a dangerous act, especially if you’re having issues with delayed messages being sent. This will also delete messages jobs (notifications and outgoing mails to customers) beside e.g. Indexing jobs.
I, [2019-03-25T08:39:32.219168 #26776-46926529974100 ] INFO – : Scheduler started.
I, [2019-03-25T08:39:32.227527 #26776-46926529974100 ] INFO – : Cleanup of left over locked delayed jobs 2019-03-25 08:39:32 UTC started.
I, [2019-03-25T08:39:32.275594 #26776-46926529974100 ] INFO – : Checking left over delayed job #<Delayed::Backend::ActiveRecord::Job id: 13895, priority: 0, attempts: 0, handler: “— !ruby/object:Observer::UserDeviceLogJob\nhttp_u…”,
last_error: nil, run_at: “2019-02-03 16:34:40”, locked_at: “2019-02-03 16:34:41”, failed_at: nil, locked_by: “host:HOSTNAME pid:30512”, queue: nil, created_at: “2019-02-03 16:34:40”, updated_at: “2019-02-03 16:34:40”> started.
I, [2019-03-25T08:39:32.360909 #26776-46926529974100 ] INFO – : Scheduler stopped.
That’s what you’re looking for; that was resolved with the full delete command. The original command in the old post didn’t work.
Okay, thanks for the feedback. Proberbly it would have been enough to just remove job ID 13895, but glad it’s working for you.
system
Closed
July 24, 2019, 11:27am
5
