Important:
- Used Zammad version: 2.6.x
- Operating system: CentOS 7.5
- Browser + version: Google Chrome Version 70.0.3538.77 (Official Build) (64-bit)
- Adding an Exchange Online email via SMTP for Outbound Email Account should work
- Got the following error:
554 5.2.0 STOREDRV.Submission.Exception:SendAsDeniedException.MapiExceptionSendAsDenied; Failed to process message due to a permanent exception with message Cannot submit message. 16.55847:46190000, 17.43559:0000000094000000000000000100000000000000, 20.52176:140FF984070010100A000270, 20.50032:140FF9848B1710101F001E31, 0.35180:98080000, 255.23226:0A007B31, 255.27962:0A000000, 255.27962:0E000000, 255.31418:120A0000, 16.55847:A4000000, 17.43559:0000000068010000000000000200000000000000, 20.52176:140FF9840700101040020000, 20.50032:140FF9848B17101049020000, 0.35180:0310A831, 255.23226:4B020000, 255.27962:0A000000, 255.27962:32000000, 255.17082:DC040000, 0.27745:D1020000, 4.21921:DC040000, 255.27962:FA000000, 255.1494:48002F30, 0.37692:02000100, 0.37948:0F010480, 5.33852:00000000534D545000000100, 4.56248:DC040000, 7.40748:010000000000010B792A89BB, 7.57132:000000000000000002000100, 1.63016:32000000, 4.39640:DC040000, 8.45434:792A89BBA67F9E4B98E5D210619FDECD3A363633, 5.10786:0000000031352E32302E313237332E3030373A534732505230324D42333536323A36363363653864322D383536612D343930302D623431642D33326634633861383132643900503000000000, 255.1750:BB070000, 255.31418:0300B131, 0.22753:50080000, 255.21817:DC040000, 4.60547:DC040000, 0.21966:0300FC31, 4.30158:DC040000 [Hostname=SG2PR02MB3562.apcprd02.prod.outlook.com]
- Open config for outbound email account
- Send mails via: SMTP
- Host: smtp.office365.com
- User: mycorpemail@example.com
- Password: my_corp_email_password
- Port: 587
- Click Continue
Update: issue resolved!
I updated it here for anyone who has the similar issue like me:
- Double check your credentials
- If your credentials are correct, you may get this error when you change your sending email address from one to another. The verification would fail because the old sender email address and the new one were mismatched.
- You need to change your sender email address (Email Address) right under the Outbound.section first. Then change your IMAP and SMTP should work.
