I, [2020-11-17T09:44:31.560851 #18851-47308676082980] INFO – : Parameters: {“data”=>"-----BEGIN CERTIFICATE-----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\r**\n**NxQCBAweCgBTAHUAYg…
I’m getting the same error with your certificate. It worked just fine with one of our certificates a couple of weeks ago (with Zammad 3.5 though). Either there is something wrong with your certificate or this is a bug.
Would it be possible to have a look at the public CA file you try to import?
One side note on this topic:
You won’t need to add a private key if you add a CA certificate. You can’t use it for signage anyway. (Ignore that hint if the certificate in your screen is not a CA certificate)
