Hello there,
is there a way to shedule the LDAP Sync? I googled a lot but didn’t found anything about it. The manual sync is working fine,
Thank you for your help!
Hello there,
Hey @anon43131755,
the LDAP sync actually is scheduled. If you want to adjust the interval in which the scheduled job is performed have a look at this:
cheers
Hello, thank you for the answer. What is the default Interval? I didn’t knew that the sync is scheduled. For me every 24 hours would be ok and for me as a Zammad Newbie it looked like the snyc is not scheduled.
Edit: I’ve check the conf File which you linked. The default Interval ist 1 hour, thats fine. Thank you very much for your help!
