Setup zammad on reverse proxy "/path" rather than "/"
Hi all,
  • Used Zammad version: 5.1.x
  • Browser + version: chrome
Thanks.
This has been raised several times on this board already.
It’s not supported by Zammad.
Zammad supports / only. Everything you try to do beside that will cause serious issues and is not supported.
Instead of using “server ips” you could also use domain names, no matter if subdomain or not. That allows you to host a lot of shit on the same system if you want to do that.
