Setting up Elastiscsearch fails: Don't know how to build task 'zammad:seachindex:rebuild'
  • Used Zammad version: zammad/unknown,now 5.1.1-1655802449.f7f1068b.bullseye amd64
  • Operating system: Debian 11 bullseye
  • Browser + version: GNU bash, version 5.1.4(1)-release (x86_64-pc-linux-gnu)
  • Search index is built
# zammad run rake zammad:searchindex:rebuild --trace
rake aborted!
Don't know how to build task 'zammad:searchindex:rebuild' (See the list of available tasks with `rake --tasks`)
Did you mean?  zammad:db:rebuild
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task_manager.rb:59:in `[]'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:159:in `invoke_task'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `each'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block in top_level'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:125:in `run_with_threads'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:110:in `top_level'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:83:in `block in run'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:80:in `run'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.7.0/bin/rake:23:in `load'
/opt/zammad/vendor/bundle/ruby/2.7.0/bin/rake:23:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/cli/exec.rb:58:in `load'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/cli/exec.rb:58:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/cli/exec.rb:23:in `run'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/cli.rb:483:in `exec'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/cli.rb:31:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/cli.rb:25:in `start'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/exe/bundle:48:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/lib/bundler/friendly_errors.rb:103:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.10/exe/bundle:36:in `<top (required)>'
/opt/zammad/bin/bundle:121:in `load'
/opt/zammad/bin/bundle:121:in `<main>'
  • run zammad run rake zammad:searchindex:rebuild --trace
How about you update to Zammad 5.2 before using a namespace changed command of 5.2?
Thanks for the hint.
Forgive me my ignorance, but this is a fresh installation. Seems like 5.2 didn’t make it to the package repository at the time of installation while the new docs got rolled out already…
Debian 11 package built for Zammad 5.2 has finished 42 minutes ago.
The documentation update was synchronous to the release roughly 3 hours ago.
Packager takes some time so.
