Set Logging Level
Important:
  • Used Zammad version: 2.4.x
  • Used Zammad installation source: Deb Pacakge
  • Operating system: N/A
  • Browser + version: Firefox
Hi, Is it possible to set the logging level of Zammad to higher than “Info” if so how is this done as I couldn’t find it in the documentation. Thanks in advance.
like config.log_level = :info to :debug ?
EDITED:
see this: http://guides.rubyonrails.org/debugging_rails_applications.html#log-levels
