- Used Zammad version: 3.5.x
- Used Zammad installation source: (source, package, …) CentOS RPM
- Operating system: AWS Linux release 2 (Karoo)
- Browser + version: Firefox Latest
- Zammad interface should load but it is not.
- All services are running, except when I try to go to my domain all I get is “403 forbidden” (previous to this, I was gettting ‘welcome to nginx amazon linux’ I deleted these files as I thought there may be a conflict, but made no difference.
- firewalld has been disabled
hostname has been changed in all configs to my FQDN that I want to use
The system has 4gb of memory is running elasticsearch and 2cores (t2.medium)
I have restarted all services
The ports currently listening are as follows:
[ec2-user@support etc]$ sudo netstat -tulpn | grep LISTEN
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 2764/rpcbind
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 4193/nginx: master
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 3652/sshd
tcp 0 0 127.0.0.1:3000 0.0.0.0:* LISTEN 12098/puma 3.12.6 (
tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 3322/postgres
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 3421/master
tcp 0 0 127.0.0.1:6042 0.0.0.0:* LISTEN 12094/script/websoc
tcp6 0 0 :::111 :::* LISTEN 2764/rpcbind
tcp6 0 0 127.0.0.1:9200 :::* LISTEN 3461/java
tcp6 0 0 ::1:9200 :::* LISTEN 3461/java
tcp6 0 0 127.0.0.1:9300 :::* LISTEN 3461/java
tcp6 0 0 ::1:9300 :::* LISTEN 3461/java
tcp6 0 0 :::22 :::* LISTEN 3652/sshd
I am stuck. Any help would be appreciated.
