[security-feature] Fix-with (monospaced) font for sender email
Title: [security-feature] Fix-with (monospaced) font for sender email
We got an email from Shopify Support <Mailer@shopfiy.com> which is a scam.
s h o p f i y (f and i is switched).
When somebody falls for the scam.
Cannot change the format in settings.
I would like to see that a fixed-with font will be used to display the sender (or better all) email addresses.
This would show immediately that some special or switched chars are used to trick the reader.
Perhaps somebody has an additional or even better idea to make such scam obvious on the first look|view.
Thanks for your time!
