Searchindex:rebuild quite slow
  • Used Zammad version: 6.4.0-1732538192.197abebd.jammy
  • Used Zammad installation type: Ubuntu package
  • Operating system: Ubuntu 22.04.5 LTS
  • Rebuilding the search index should use the full capacity of the server
  • Rebuilding the search index for 14000 tickets takes hours. However the CPU usage ist not more than 30 %.
  • sudo zammad run rake zammad:searchindex:rebuild
Is there any way to speed rebuildung the search index up? Where should I search for the bottleneck?
Yes, the documentation has you covered:
https://docs.zammad.org/en/latest/install/elasticsearch.html#step-3-connecting-zammad-with-elasticsearch
Thanks a lot, MrGeneration! That works fine.
