Searchindex:rebuild fails
  • Used Zammad version: 3.6
  • Operating system: Centos 6
  • Browser + version: not applicabale
  • zammad run rake searchindex:rebuild rebuilds all indexes and restores Search function after updating zu zammad 3.6
  • drop indexes…done
    delete pipeline (pipeline)… done
    create indexes…done
    create pipeline (pipeline)… done
    reload data…
    reload Chat::Session
    • started at 2021-01-14 08:31:48 UTC
    • took 0 seconds
      reload Cti::Log
    • took 0 seconds
      reload KnowledgeBase::Answer::Translation
    • took 0 seconds
      reload KnowledgeBase::Category::Translation
    • took 0 seconds
      reload KnowledgeBase::Translation
    • took 0 seconds
      reload Ticket
      rake aborted!
      Unable to send Ticket.find(54423).search_index_update_backend backend: #<RuntimeError: Unable to process POST request to elasticsearch URL ‘http://127.0.0.1:9200/zammad_production_ticket/_doc/54423?pipeline=zammad731495648940’. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x00005610724b86a0 @success=false, @body="{“error”:{“root_cause”:[{“type”:“cluster_block_exception”,“reason”:“blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];”}],“type”:“cluster_block_exception”,“reason”:“blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];”},“status”:403}", @data=nil, @code=“403”, @content_type=nil, @error=“Client Error: #<Net::HTTPForbidden 403 Forbidden readbody=true>!”>
Payload:
{“id”=>54423, “group_id”=>5, “priority_id”=>3, “state_id”=>3, “organization_id”=>nil, “number”=>“2019053116000529”, …
  • zammad run rake searchindex:rebuild using root user
is there any option to skip a certain id or force option to carry on after failure?
If I’d had to guess I’d say you have 10% or less free storage left.
Elasticsearch changes into read only for safety reasons if you get below a specific percentage of available storage.
You should also be able to see that in it’s log file.
