- Used Zammad version: 3.5.0, Release 1603788665.5a776fce.centos7
- Used Zammad installation source: RPM from Repo
- Operating system: CentOS 7.8.2003
- Browser + version: Not relevant
Problem description
After an zammad update (yum update zammad
) I wanted to recreate the index because I had the impression, that it was incomplete. When running zammad run rake searchindex:rebuild --trace
I am now getting the following error trace, which I don’t understand:
[root]# zammad run rake searchindex:rebuild --trace
** Execute environment
** Execute searchindex:rebuild
** Execute searchindex:drop
drop indexes...done
** Execute searchindex:drop_pipeline
** Execute searchindex:create
create indexes...done
** Execute searchindex:create_pipeline
create pipeline (pipeline)... rake aborted!
Unable to process put request to elasticsearch URL 'http://127.0.0.1:9200/_ingest/pipeline/zammad558842541452'. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x00005633f199c408 @success=false, @body="{\"error\":{\"root_cause\":[{\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\",\"suppressed\":[{\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\"}]}],\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\",\"suppressed\":[{\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\"}]},\"status\":400}", @data=nil, @code="400", @content_type=nil, @error="Client Error: #<Net::HTTPBadRequest 400 Bad Request readbody=true>!">
Payload:
{"description":"Extract zammad-attachment information from arrays","processors":[{"foreach":{"field":"article","processor":{"foreach":{"field":"_ingest._value.attachment","processor":{"attachment":{"target_field":"_ingest._value","field":"_ingest._value._content","ignore_failure":true,"ignore_missing":true}},"ignore_failure":true,"ignore_missing":true}},"ignore_failure":true,"ignore_missing":true}},{"foreach":{"field":"attachment","processor":{"attachment":{"target_field":"_ingest._value","field":"_ingest._value._content","ignore_failure":true,"ignore_missing":true}},"ignore_failure":true,"ignore_missing":true}}]}
Payload size: 0M
/opt/zammad/lib/search_index_backend.rb:895:in `make_request_and_validate'
/opt/zammad/lib/search_index_backend.rb:84:in `block (2 levels) in processors'
/opt/zammad/lib/search_index_backend.rb:68:in `each'
/opt/zammad/lib/search_index_backend.rb:68:in `block in processors'
/opt/zammad/lib/search_index_backend.rb:65:in `each'
/opt/zammad/lib/search_index_backend.rb:65:in `processors'
/opt/zammad/lib/tasks/search_index_es.rake:95:in `block (2 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `block in execute'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `execute'
/opt/zammad/lib/tasks/search_index_es.rake:67:in `block (2 levels) in <main>'
/opt/zammad/lib/tasks/search_index_es.rake:178:in `block (2 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:214:in `block in invoke_with_call_chain'
/opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:194:in `invoke_with_call_chain'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:183:in `invoke'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:160:in `invoke_task'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `block in top_level'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:125:in `run_with_threads'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:110:in `top_level'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:83:in `block in run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:80:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/bin/rake:23:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/bin/rake:23:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:28:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:463:in `exec'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor.rb:387:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:27:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/base.rb:466:in `start'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:18:in `start'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:30:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/friendly_errors.rb:124:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:22:in `<top (required)>'
[roo]#
Any help or hint helping me understand what is going wrong in detail is highly appreciated.
Thanks
