Searchbar not working anymore
  • Used Zammad version: 6.4.1
  • Used Zammad installation type: Docker
  • Operating system: CentOS
  • Browser + version: Chrome, latest version as of submission date
  • Using the searchbar retruns found items
  • Using the search bar in not much if anything being found
  • Enter something in the searchbar find nothing. Go into settings => Overviews => create or edit one => add a condition on the field you want to serach => Enter the same value as from the searchbar => It finds the tickets.
    I have no idea what is wrong or how to even start to troubleshot this.
What a coincidence i have the exact same problem. What im currently trying is to rebuild the elasticsearch search index.
docker exec zammad-docker-compose-zammad-railsserver-1 /docker-entrypoint.sh bundle exec rake zammad:searchindex:rebuild
Mine is currently still reindexing but i think that will fix it.
I though that this is the problem too, but I thought that since I was able to search in other places that it can not be. But I am rebuilding it too thanks to you. I will keep you notified once it finishes. Hopefully that was really the problem all along and I should trust my guts more.
Yeah that worked. Most if not all are now searchable. Thank you very much!
