Used Zammad version: Zammad version 6.3.1-17
Operating system: Red Hat Enterprise Linux release 9.4
Browser + version: chrome 125.0.6422.113
search function works correctly
search function do not works correctly after updating zammad to 6.3 and elastic search to 7.17.21
I have installed /usr/share/elasticsearch/bin/elasticsearch-plugin install ingest-attachment
the out put of zammad run rake searchindex:rebuild --trace
rake aborted!
Don't know how to build task 'searchindex:rebuild' (See the list of available tasks with `rake --tasks`)
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task_manager.rb:59:in `[]'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:181:in `invoke_task'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:138:in `block (2 levels) in top_level'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:138:in `each'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:138:in `block in top_level'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:147:in `run_with_threads'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:132:in `top_level'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:83:in `block in run'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:208:in `standard_exception_handling'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:80:in `run'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/3.2.0/bin/rake:25:in `load'
/opt/zammad/vendor/bundle/ruby/3.2.0/bin/rake:25:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli/exec.rb:58:in `load'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli/exec.rb:58:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli/exec.rb:23:in `run'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli.rb:492:in `exec'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/vendor/thor/lib/thor.rb:527:in `dispatch'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli.rb:34:in `dispatch'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/vendor/thor/lib/thor/base.rb:584:in `start'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/cli.rb:28:in `start'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/exe/bundle:37:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/bundler-2.4.22/exe/bundle:29:in `<top (required)>'
/opt/zammad/bin/bundle:121:in `load'
/opt/zammad/bin/bundle:121:in `<main>'
The namespace has been changed some versions before. Please consider reading release notes in the future, as some of these announced changes might break your neck unprepaired.
It’s zammad run rake zammad:searchindex:rebuild
now.
(Updating Zammad — Zammad System Documentation documentation )
Yes,it works thank you for the help.
system
Closed
June 7, 2024, 10:57am
4
