Scheduler UI missing in Helm/Kubernetes deployment (Zammad 6.5)
  • Used Zammad version: 6.5
  • Used Zammad installation type: Helm chart (official) in Kubernetes
  • Operating system: Zammad Docker containers on Kubernetes (EKS)
  • Browser + version: Chrome (latest), also tested in Safari
  • The zammad-scheduler pod is running and successfully executing background jobs (e.g. DataPrivacyTask.create! via Rails works as expected).
  • However, the Scheduler UI is not visible in the admin interface at all.
  • We tried creating a scheduler_enabled setting via Rails console, but that setting seemts to longer exists in Zammad 6.5.
  • No way to enable the Scheduler UI was found in the documentation or Helm chart values.
  • Deploy Zammad 6.5 via the official Helm chart in Kubernetes
  • Ensure zammad-scheduler pod is running
  • Open the admin interface
  • Check under Admin → System: Scheduler UI is missing
  • Attempt to enable via Rails console: Setting.create!(...) fails due to missing attributes
Check your users permissions. I bet you do not have full administrative permissions. If you do, you might want to share your role configurations. The settings you’ve tried to use never existed btw. There’s no “hide that stuff”.
Thanks for clarification. My user has “full administrative permissions”.
