- Used Zammad version: 5.2.x
- Operating system: Debian 11 bullseye
- Browser + version: Firefox 102
- A scheduler job scheduled for 01:00 should match a “<custom date field> before (relative) 1 minute(s)” condition when the date is today.
- The condition doesn’t match on that day, but only the next day.
We have a custom date field “followup” on our Ticket object:
This is used as an alternative way to the “pending reminder” ticket state to reopen a ticket on a certain date, regardless of the ticket state.
A scheduler is supposed to reopen tickets on that day:
This has stopped working after a recent update:
Martin von Wittich - 2022-07-26 17:58
updated Ticket State from 'open' → 'closed' updated Ticket last_owner_update_at '01/11/2021 19:38' → '-' updated Ticket Wiedervorlage '2022-07-27'
2022-07-28 01:01updated Ticket State from 'closed' → 'open' updated Ticket last_owner_update_at '07/28/2022 01:01' updated Ticket Wiedervorlage '2022-07-27' → '-' created Article notification Ticket 'martin.von.wittich@iserv.eu(update:online)'
I would have expected the scheduler to reopen the ticket on 2022-07-27 01:01, but instead it only reopened the ticket on 2022-07-28 01:01.
Apparently, the scheduler runs correctly at the configured time (the ticket history says 01:01 which matches the scheduler configuration), but it doesn’t match the condition.
I believe that this is a timezone bug - our local timezone is CEST (UTC+2), so when the scheduler is running at 2022-07-27 01:01 UTC+2, it’s internally probably thinking in UTC, and so it sees the current time as 2022-07-26 23:01 UTC. It then probably compares the date field “2022-07-27” with “2022-07-26 23:01 UTC” and this results in the condition not matching. It works on the next day because then it’ll compare the date field “2022-07-27” with “2022-07-27 23:01 UTC”.
I suspect that the following change might be responsible for the issue:
- Job scheduling respects time zone 3802
Can anyone confirm that this is indeed a bug, or am I barking up the wrong tree?
