Scheduler is set to delete all tickets that have been given the “spam” tag every night
** Conditions: Tags → contains all → spam
** Execute changes: Action → delete and State → closed
Scheduler shows that it has already processed >10k tickets, expected behavior is that these are removed from the system permanentyl
even though scheduler shows ticket processing these are not removed from Zammad
create scheduler with the configuration mentioned above, give tickets a “spam” tag
Yes, but to be completely honest I do not know why. I am sure someone must have changed something in the Zammad configuration, but so far I have not hunted that info since I was simply happy that it worked and I could take my mind elsewhere.
Only thing I saw was that the amount of tickets in my overviews dropped from 10k to 100 over the course of a few days.
The scheduler only had to process tickets with a spam tag, regardless of state. But since I also have a trigger that closes tickets tagged as spam and I also had a trigger that sets a spam tag for certain topics and sender domains, I would guess that the schedulere only had to process closed tickets, not deleted tickets.
Hi, I have re-checked the schedulers, and they indeed all now only have the action “delete”. Seems that this might have done the trick, although I did not follow up on whether the change to actions was what triggered the scheduler to actually work. But I will keep that in mind in the future, thanks a lot!
Does that mean that schedulers will not process tickets in general if there are more actions after the delete action?
