A custom attribute is used as a main identifier in SAML-SSO. (Keycloak used). This is automatically used as login in Zammad. -
The custom attribute is cryptic and more readable login should be used. -
Because the attribute that is used for mapping into the login-field is not configurable. -
Make the mapping configurable.
Your Zammad environment:
- Average concurrent agent count: 3 digits
- Average tickets a day: 1-2 digits
- What roles/people are involved: Agents/Admins
