SAML Auth not mapping accounts
Hi there,
just activated saml auth via ADFS in our self hosted instance.
Authentication generally works but is there a chance for mapping exisiting local auth accounts to the new saml login accounts?
If I try to login with my account the log is telling me:
Validation failed: Email address 'XXX@XXX' is already used for another user. (Exceptions::UnprocessableEntity)
If you need more information just tell me.
Thanks!
Should the mapping work automatically or is there a setting that has to be activated?
I found the solution myself, I simply overlooked a setting:
