S/MIME and formatting bugs
  • Used Zammad version: 6.1
  • Operating system: Ubuntu
  • Client-OS: MacOS 14.1
  • Browser + version: MS Edge 119.0.2151.46, Safari 17.1 and Firefox 119
We encountered a few bugs. If desired I could split it up into three different topics.
S/MIME cert download
  • To be able to download the uploaded S/MIME certificates from the integration page
  • Trying to download a certificate results in a 500 error from server
  • Downloading a private key works
  • No errors in production log
  • Upload a certificate (with or without private key)
  • Try downloading a certificate
  • Depending on browser the download fails or you receive a html file with the 500 error page contents
Safari: no “paste from clipboard (text only)” shortcut
  • Paste from clipboard as text-only in Safari with “cmd + shift + v”
  • Nothing happens if “cmd + shift + v” is pressed
  • No errors in browser console
  • copy something to clipboard
  • try pasting with “cmd + shift + v”
  • normal pasting with “cmd + v” works
  • pasting with “cmd + shift + v” in MS Edge and FF works normal
Safari: weird formatting behavior in dark mode
  • removing and adding line breaks should not alter the formatting
  • If line breaks are removed and then added via “return” the formatting is fixed to dark mode style
  • this results in white font color and black background in outgoing mails
  • I have recorded the behavior safari-formatting
  • start in dark mode
  • write a normal article with multiple paragraphs in one go
  • check formatting in light mode
  • change back to dark mode
  • remove line break and readd via “return”
  • We could not reproduce it in MS Edge and FF
