Used Zammad installation source: (source, package, …)DEB
Operating system: Ubuntu 18.04
Browser + version: Safari
I moved the server with backup option and restored on the other end, except for the ubuntu version everything is the same, but when I do run rake assets:precompile it just hangs and does nothing!
$ sudo zammad run rake assets:precompile
WARNING: Nokogiri was built against LibXML version 2.9.3, but has dynamically loaded 2.9.4
(sudo) zammad run rake assets:precompile imho is the only way to recompile your stuff.
Technically it’s possible that the precompiling takes a bit longer.
Did you modify anything? Maybe you have corrupt files or so.
