I’m sure you received an error on your console.
Please post console output here - it’s important to carefully run those commands, as it destroys stuff.
There might be a security switch forbidding you to break it.
/usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver.rb:231:in search_for': Unable to resolve dependency: user requested 'did_you_mean (= 1.1.0)' (Gem::UnsatisfiableDependencyError) from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver.rb:283:inblock in sort_dependencies’
from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver.rb:277:in each' from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver.rb:277:insort_by’
from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver.rb:277:in with_index' from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver.rb:277:insort_dependencies’
from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver/molinillo/lib/molinillo/delegates/specification_provider.rb:52:in block in sort_dependencies' from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver/molinillo/lib/molinillo/delegates/specification_provider.rb:69:inwith_no_such_dependency_error_handling’
from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver/molinillo/lib/molinillo/delegates/specification_provider.rb:51:in sort_dependencies' from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver/molinillo/lib/molinillo/resolution.rb:165:ininitial_state’
from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver/molinillo/lib/molinillo/resolution.rb:106:in start_resolution' from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver/molinillo/lib/molinillo/resolution.rb:64:inresolve’
from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver/molinillo/lib/molinillo/resolver.rb:42:in resolve' from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/resolver.rb:188:inresolve’
from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/request_set.rb:396:in resolve' from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems/request_set.rb:408:inresolve_current’
from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems.rb:243:in finish_resolve' from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems.rb:311:inblock in activate_bin_path’
from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems.rb:309:in synchronize' from /usr/local/rvm/rubies/ruby-2.4.4/lib/ruby/site_ruby/2.4.0/rubygems.rb:309:inactivate_bin_path’
from /usr/local/rvm/gems/ruby-2.4.4@global/bin/rake:23:in <main>' from /usr/local/rvm/gems/ruby-2.4.4/bin/ruby_executable_hooks:24:ineval’
from /usr/local/rvm/gems/ruby-2.4.4/bin/ruby_executable_hooks:24:in `’
Thanks for the feedback, I didn’t add this information on porpose, as this is a dangerous command.
That was the reason why I originally told you to read the output from your command (because I was expecting you to encounter this ^^")
Hi MrGeneration,
I agree with you - up to a certain point.
I understand a “manual” as documentation that also helps new users to accomplish their goals. At least within the community when asking for suggestions I expected to get a “working set” of commands.
I have a quite a few years years experience in IT and can clearly seee stars where others fail. But in this case I am totally new to a) zammad as a product, and b) ruby / rails as framework. So when I take a look into the docs an find a paragraph about how to reset the complete system I assumed to find a working set of commands. This would have included the parameter to force the reset, as shown above.
I agree: This is dangerous. But I prefer to have the full wokring command set there, alongside a “Warning!” disclaimer to serve new users. That’s what I mean with “polish” the docs.
BTW:
I also had problems installing Zammad at all. Yes, there is whole set of installation manuals referencing prerequisites back and forth, but if the team could provide -let’s say- a script that does all the installation-steps (or at least checks the prerequisites) from a naked system into a proven working clean installation this would make life easier for newbees. More capable people the could check and tweak the script or do their full manual installation.
Maybe that’s worth a thought
Thanks for your feedback, for us that’s important.
I personally am quite scared to do such things (not deleting stuff but giving a 1 to 1 description), as I had to learn, that many people to ignore warnings and information in bolt text - afterwards they come to you and blame you.
But I’ll discuss this inside of our team, we’ll surely find a working solution
Regarding a full installation script, I’m not sure if it’s a completely good idea, because we have to support it, if we have it. That might cause further trouble, but I’ll think about it. (again, your opinion is highly apprieciated)
