Where does this error appear?
What does your logfile say?
Whats your hardware ressource configuration on your Host?
Side note: Please note that Zammad 3.1 is depreacted and there were important security updates introduced with Zammad 3.3 - you might want to consider upgrading.
This is the same with ours. we encounter this. just now. how can we upgrade to zammad3.3. I got this error: W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging yarn@dan.cx
W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging yarn@dan.cx
W: Some index files failed to download. They have been ignored, or old ones used instead.
I follow this instructions: W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging yarn@dan.cx
Hope to hear from you. because now it is totally down.
The error you mentioned is an issue with your package manager where I can’t help sorry, that’s out of scope.
Beside, I don’t understand what you mean by “It’s down” (that’s not an error message that helps to help you). The above errors suggest that you couldn’t upgrade Zammad at all.
