Reports Missing Data
  • Used Zammad version: 5.0.x
  • Operating system: Ubuntu 20
  • Browser + version: firefox 99.0.1
I noticed that some of my report profiles are missing data. I have a profile that selects all open tickets and a large number of tickets are missing. I created a new profile selecting state of open and a specific organization and I can see the tickets in the preview pane
But when I go to the reporting menu and select that report profile that I just created, it is empty
Am I doing something wrong and or how do I resolve this ?
I went searching on reports and I ran across a couple of posts that mentioned rebuilding the elasticsearch search index. I used he following command on the linux command line sudo zammad run rake searchindex:rebuild
Nothing jumped out at me BUT it does seem that the my report does show the missing data. Should I put this in CRONTAB and preform it every so often ???
drop indexes...done
create indexes...done
create pipeline (pipeline)... done
reload data...
 reload Group
  - started at 2022-04-18 16:44:58 UTC
        7/7
  - took 0 seconds
 reload Ticket
        42/42
  - took 7 seconds
 reload Organization
  - started at 2022-04-18 16:45:06 UTC
        26/26
  - took 0 seconds
 reload Chat::Session
  - took 0 seconds
 reload Ticket::State
        7/7
  - took 0 seconds
 reload Ticket::Priority
  - started at 2022-04-18 16:45:07 UTC
        3/3
  - took 0 seconds
 reload User
        31/31
  - took 0 seconds
 reload KnowledgeBase::Category::Translation
        2/2
  - took 0 seconds
 reload KnowledgeBase::Translation
        1/1
  - took 0 seconds
 reload KnowledgeBase::Answer::Translation
        3/3
  - took 0 seconds
 reload Cti::Log
  - started at 2022-04-18 16:45:08 UTC
  - took 0 seconds
 reload StatsStore
        6/6
  - took 0 seconds
Crontab the elasticserach index rebuild good idea Yeah Nay if Yeah how often ?
P.S. I have not had another incident of reports not working
Jfyi, I have a similar issue with elasticsearch:
https://community.zammad.org/t/elasticsearch-forgets-results-from-attachments-over-time/
Maybe the underlaying problem is the same.
Anyway, yes, although not a real solution cron does help. :slightly_smiling_face:
I’m not sure why my index disappeared and luckily I only had to rebuild it once. I do know that some (if not all) of the tickets created had .pdf attachments
If it becomes a problem for me I’ll add your crontab solution
# elasticsearch attachments index workaround  At minute 7 past every 3rd hour
7 */3  * * *   root    zammad run rake searchindex:rebuild > /dev/null
Just don’t.
Like really. It’s no solution and brings more issues than solving issues.
:ok_hand: I’ll only do it if searches and reports don’t work
