Reporting tools
hi
I’m trying to learn about zammad and new in using it
I found that I can use Grafana with Zammad as reporting tools
but to configure Zammad with Grafana I should have hosted Zammad .
is there any other way to connect Zammad with Grafana directly without Hosted ?
I want to install Zammad and Grafana On my own server … if the hosted is the only way … is there any other tools work like Grafana and I can use it to reporting and it working with Zammad ?
Thank you everyone
Who said you can use Grafana with SaaS only?
It’s available for all installation methods as explained in our documentation.
I tried to connect Grafana with Zammad through ElasticSearch
I followed the Doc I found , when I reach the connection through elasticsearch point I couldn’t find “elasticsearch” in the “Integration” section on Zammad panel to get the elasticsearch server info for making the connection
so I couldn’t make the connection with grafana
I really Appreciate any help cause I’m lost and don’t know what to do
The documentation clearly states why.
And the Grafana related documentation tells you how you get the information on on premise actually…
https://docs.zammad.org/en/latest/appendix/reporting-tools-thirdparty/grafana.html
If the documentation doesn’t help you or you’re stuck, maybe this helps.
This video takes you by the hand from installation to configuration on the same machine.
