Used Zammad version: 3.1.x
Used Zammad installation source: package
Browser + version: Mozilla Firefox
When I define a report-profile to filter based on a certain “particularity” (not sure if this is the proper word, see images) it won’t produce any information. Attaching a label with the same text does.
It does not report anything when checking for the defined “particularities”, however it does show that it can find information.
So it seems to me that it should be working just fine…
Looks like this issue:
Used Zammad version: 3.1 and earlier
Installation method (source, package, ..): any
Operating system: any
Database + version: any
Elasticsearch version: any (but verified von...
bug
prioritized by payment
reporting
verified
If so, this should be adressed with Zammad 3.2 coming this week.
If you could check again when updated, that would be amazing.
If it still doesn’t work, please let us know, I’ll have another look then.
Thank you for the reply. I will check back in a week.
Kind regards
system
closed
April 1, 2020, 9:45am
#4
