Currently, there are three ways to run automated adjustments to objects (mostly tickets):
- Macros
- Trigger
- Scheduler
While they mainly cover the same “actions” available to make adjustments, they differ in detail. Even more, since Schedulers are now available for User/Organization-objects as well.
The idea is to replace them with a combined actionflow (name tbd) model, that consist of one or more activators and one action.
The activators will be replacements for the existing possibilities:
- Manually (currently macro)
- Action based (currently trigger)
- Time event (currently trigger)
- Scheduled (currently scheduler)
And the actions will be something similar to what we have in schedulers now.
The vision is to replace macros/triggers/schedulers with one screen of “actionflows” (name tbd), that can have one or more activators.
This would solve two major issues with the current model:
- If you have more than one activator you don’t need to create two entities (e.g. a macro and a trigger that do the same).
- We get rid of the differences in the possible action sets (e.g. why is it not possible to send mails via Macros?)
