Hello.
Zammad 3.3.x on Centos 7 from package. NGINX web server.
I noticed repeated errors in production log. But, I do not see any problems with helpdesk. Logins from LAN, Internet, Google auth, Office365 auth, LDAP integration, local login - all good.
Please advice, what can be a reason for this repeated errors?
============= production.log fragment ================================
I, [2020-03-10T10:18:44.305659 #60786-47008776398020] INFO – : Started POST “/api/v1/message_send” for 10.10.10.253 at 2020-03-10 10:18:44 +0200
I, [2020-03-10T10:18:44.313141 #60786-47008776398020] INFO – : Processing by LongPollingController#message_send as JSON
I, [2020-03-10T10:18:44.313245 #60786-47008776398020] INFO – : Parameters: {“data”=>{“event”=>“login”}}
I, [2020-03-10T10:18:44.314340 #60786-47008776398020] INFO – : CSRF token verification failed
E, [2020-03-10T10:18:44.314767 #60786-47008776398020] ERROR – : Error ID gCjuPEXb: CSRF token verification failed!
E, [2020-03-10T10:18:44.315086 #60786-47008776398020] ERROR – : Error ID JuLRA7RO: CSRF token verification failed!
I, [2020-03-10T10:18:44.315941 #60786-47008776398020] INFO – : Completed 401 Unauthorized in 2ms (Views: 0.5ms | ActiveRecord: 0.0ms)
I, [2020-03-10T10:18:45.482548 #60786-70127398960540] INFO – : Completed 200 OK in 25027ms (Views: 0.3ms | ActiveRecord: 1.3ms)
I, [2020-03-10T10:18:45.541998 #60786-47008779189880] INFO – : Started POST “/api/v1/message_receive” for 10.10.10.253 at 2020-03-10 10:18:45 +0200
I, [2020-03-10T10:18:45.553055 #60786-47008779189880] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2020-03-10T10:18:45.553285 #60786-47008779189880] INFO – : Parameters: {“client_id”=>“7462264792”}
I, [2020-03-10T10:18:49.095058 #60786-70127391531040] INFO – : Completed 200 OK in 25031ms (Views: 0.2ms | ActiveRecord: 2.0ms)
I, [2020-03-10T10:18:49.148591 #60786-47008776398020] INFO – : Started POST “/api/v1/message_receive” for 10.10.10.253 at 2020-03-10 10:18:49 +0200
I, [2020-03-10T10:18:49.158944 #60786-47008776398020] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2020-03-10T10:18:49.159036 #60786-47008776398020] INFO – : Parameters: {“client_id”=>“8703627373”}
I, [2020-03-10T10:18:55.220892 #60786-70127398960540] INFO – : Started POST “/api/v1/message_send” for 10.10.10.253 at 2020-03-10 10:18:55 +0200
I, [2020-03-10T10:18:55.232937 #60786-70127398960540] INFO – : Processing by LongPollingController#message_send as JSON
I, [2020-03-10T10:18:55.233061 #60786-70127398960540] INFO – : Parameters: {“data”=>{“event”=>“login”}}
I, [2020-03-10T10:18:55.233794 #60786-70127398960540] INFO – : CSRF token verification failed
E, [2020-03-10T10:18:55.234545 #60786-70127398960540] ERROR – : Error ID _YCVsPM8: CSRF token verification failed!
E, [2020-03-10T10:18:55.234770 #60786-70127398960540] ERROR – : Error ID 9UIKMIiu: CSRF token verification failed!
I, [2020-03-10T10:18:55.235085 #60786-70127398960540] INFO – : Completed 401 Unauthorized in 2ms (Views: 0.1ms | ActiveRecord: 0.0ms)
I, [2020-03-10T10:18:58.608769 #60786-47008826252780] INFO – : Completed 200 OK in 25031ms (Views: 0.4ms | ActiveRecord: 1.6ms)
I, [2020-03-10T10:18:58.664662 #60786-70127391531040] INFO – : Started POST “/api/v1/message_receive” for 10.10.10.253 at 2020-03-10 10:18:58 +0200
I, [2020-03-10T10:18:58.671883 #60786-70127391531040] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2020-03-10T10:18:58.671977 #60786-70127391531040] INFO – : Parameters: {“client_id”=>“7906539403”}
I, [2020-03-10T10:19:06.282968 #60786-70127398960540] INFO – : Started POST “/api/v1/message_send” for 10.10.10.253 at 2020-03-10 10:19:06 +0200
I, [2020-03-10T10:19:06.289004 #60786-70127398960540] INFO – : Processing by LongPollingController#message_send as JSON
I, [2020-03-10T10:19:06.289077 #60786-70127398960540] INFO – : Parameters: {“data”=>{“event”=>“login”}}
I, [2020-03-10T10:19:06.289477 #60786-70127398960540] INFO – : CSRF token verification failed
E, [2020-03-10T10:19:06.289591 #60786-70127398960540] ERROR – : Error ID VOPww2js: CSRF token verification failed!
E, [2020-03-10T10:19:06.289734 #60786-70127398960540] ERROR – : Error ID 9BgvDGsT: CSRF token verification failed!
I, [2020-03-10T10:19:06.290023 #60786-70127398960540] INFO – : Completed 401 Unauthorized in 1ms (Views: 0.2ms | ActiveRecord: 0.0ms)
