[LOW LEVEL REQUEST]
Title: Please remove inline images from quotes.
Usually when answering tickets agents send those inline images out again, or have to manually remove them form the quoted text. -
When the answer could not be processed (see screenshot).
We get an error “Status Code 413” then.
It could be solved by not quoting, but this … well … would not quote. -
Not sending out the images the customer sent.
I think inline images should be removed. Perhaps replaced with an “empty” img tag just providing the alt text.
Why: because they can get large. We do not reply with the original attachments, so we should not waste space ect with inline images.
Thank you.
