When a person has an acount with LDAP on the zammad server and sends an e-mail to a internal email address, that is only a direct redirect to the zammad e-mail address than the customer should be the sender of the e-mail.
When a person has an acount with LDAP on the zammad server and sends an e-mail to a internal email address, that is only a direct redirect to the zammad e-mail address than the customer is not the email sender, but the e-mail address that the mail is send to.
get a mail-server
create an e-mail accout for your zammad
redirect the e-mails to your zammad ( that redirect should not be an accout that has an IMAP/POP3 account)
get a LDAP server
make there an account
connect LDAP with zammad
send an e-mail to the redirect e-mail address
the customer is automatically the redirect e-mail address and not the one that sended the mail initialy
when you remove LDAP connection and the account and than send a mail with the previous mail that had a LDAP account the identification works and the customer is the actual sending e-mail.
the reason for that ticket:
when you press answer on the ticket the mail gets automatically send to the customer and not to the one who created the ticket.
Have you tried using the setting “Sender based on Reply-To header” under settings → channels → email? That could do the trick. Or you have to change the way the e-mails are forwarded. Depending on how you set that up you might have different options how mails are forwarded.
has no effect in my case (i don’t know why cause it seems to fit).
I restarted zammad to be sure that the option is active.
What i can do is setup an IMAP account on my mailserver for the redirect and than it works but that feels kinda redundant.
Or i remove my LDAP connection, but that is even worse in my opinion.
im sorry for the delayed update
after the update from Ubuntu 20.04.5 to 22.04.4 LTS
and the update from
5.2.3 to 6.2.0-1709731059.4024f79c.jammy helped to fix my problem
as a side info i use
Postgresql version: 14+238
