- Used Zammad version: 5.1.1
- Used Zammad installation type: package from apt-repo
- Operating system: debian bullseye
- Browser + version: Firefox 100
zammad run rake searchindex:rebuild --trace fails when it tries to reindex Organizations.
** Execute environment
** Invoke searchindex:configured (first_time)
** Execute searchindex:configured
** Execute searchindex:rebuild
** Execute searchindex:drop
drop indexes…done
** Execute searchindex:drop_pipeline
delete pipeline (pipeline)… done
** Execute searchindex:create
create indexes…done
** Execute searchindex:create_pipeline
create pipeline (pipeline)… done
** Execute searchindex:reload
reload data…
reload User
- started at 2022-05-13 08:45:31 UTC
100/2723
200/2723
300/2723
400/2723
500/2723
zammad run rake searchindex:rebuild --trace 600/2723
700/2723
800/2723
900/2723
1000/2723
1100/2723
1200/2723
1300/2723
1400/2723
1500/2723
1600/2723
1700/2723
1800/2723
1900/2723
2000/2723
2100/2723
2200/2723
2300/2723
2400/2723
2500/2723
2600/2723
2700/2723
2723/2723 - took 19 seconds
reload Cti::Log - started at 2022-05-13 08:45:50 UTC
- took 0 seconds
reload Group - started at 2022-05-13 08:45:50 UTC
2/2 - took 0 seconds
reload Organization - started at 2022-05-13 08:45:50 UTC
rake aborted!
Unable to send Organization.find(2327).search_index_update_backend backend: #<NoMethodError: undefined methodlookup' for TrueClass:Class> /opt/zammad/app/models/concerns/has_search_index_backend.rb:231:in
rescue in block in search_index_reload’
/opt/zammad/app/models/concerns/has_search_index_backend.rb:225:inblock in search_index_reload' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/relation/delegation.rb:88:in
each’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/relation/delegation.rb:88:ineach' /opt/zammad/config/initializers/active_record_as_batches.rb:27:in
as_batches’
/opt/zammad/config/initializers/active_record_as_batches.rb:44:inas_batches' /opt/zammad/app/models/concerns/has_search_index_backend.rb:223:in
/opt/zammad/lib/tasks/search_index_es.rake:50:inblock (3 levels) in <main>' /opt/zammad/lib/tasks/search_index_es.rake:46:in
each’
/opt/zammad/lib/tasks/search_index_es.rake:46:inblock (2 levels) in <main>' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in
block in execute’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:ineach' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in
execute’
/opt/zammad/lib/tasks/search_index_es.rake:65:inblock (2 levels) in <main>' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in
block in execute’
execute’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:219:inblock in invoke_with_call_chain' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in
synchronize’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:ininvoke_with_call_chain' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:188:in
invoke’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:160:ininvoke_task' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in
block (2 levels) in top_level’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:ineach' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in
block in top_level’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:125:inrun_with_threads' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:110:in
top_level’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:83:inblock in run' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:186:in
standard_exception_handling’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:80:inrun' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in
<top (required)>’
/opt/zammad/vendor/bundle/ruby/2.7.0/bin/rake:23:inload' /opt/zammad/vendor/bundle/ruby/2.7.0/bin/rake:23:in
<top (required)>’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli/exec.rb:58:inload' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli/exec.rb:58:in
kernel_load’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli/exec.rb:23:inrun' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli.rb:479:in
exec’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/vendor/thor/lib/thor/command.rb:27:inrun' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in
invoke_command’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/vendor/thor/lib/thor.rb:392:indispatch' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli.rb:31:in
dispatch’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/vendor/thor/lib/thor/base.rb:485:instart' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli.rb:25:in
start’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/exe/bundle:49:inblock in <top (required)>' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/friendly_errors.rb:103:in
with_friendly_errors’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/exe/bundle:37:in<top (required)>' /opt/zammad/bin/bundle:121:in
load’
/opt/zammad/bin/bundle:121:in `’
Caused by:
NoMethodError: undefined method lookup' for TrueClass:Class /opt/zammad/app/models/application_model/can_lookup_search_index_attributes.rb:104:in
search_index_value_by_attribute’
/opt/zammad/app/models/application_model/can_lookup_search_index_attributes.rb:66:in block in search_index_attribute_lookup' /opt/zammad/app/models/application_model/can_lookup_search_index_attributes.rb:41:in
each’
/opt/zammad/app/models/application_model/can_lookup_search_index_attributes.rb:41:in search_index_attribute_lookup' /opt/zammad/app/models/organization/search_index.rb:8:in
search_index_attribute_lookup’
/opt/zammad/app/models/concerns/has_search_index_backend.rb:178:in search_index_update_backend' /opt/zammad/app/models/concerns/has_search_index_backend.rb:226:in
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/relation/delegation.rb:88:in each' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/relation/delegation.rb:88:in
each’
/opt/zammad/config/initializers/active_record_as_batches.rb:27:in as_batches' /opt/zammad/config/initializers/active_record_as_batches.rb:44:in
as_batches’
/opt/zammad/app/models/concerns/has_search_index_backend.rb:223:in search_index_reload' /opt/zammad/lib/tasks/search_index_es.rake:50:in
block (3 levels) in ’
/opt/zammad/lib/tasks/search_index_es.rake:46:in each' /opt/zammad/lib/tasks/search_index_es.rake:46:in
block (2 levels) in ’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in block in execute' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in
each’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in execute' /opt/zammad/lib/tasks/search_index_es.rake:65:in
each’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in execute' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:219:in
block in invoke_with_call_chain’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in synchronize' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:188:in invoke' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:160:in
invoke_task’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in block (2 levels) in top_level' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in
each’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in block in top_level' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:125:in
run_with_threads’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:110:in top_level' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:83:in
block in run’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:186:in standard_exception_handling' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:80:in
run’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in <top (required)>' /opt/zammad/vendor/bundle/ruby/2.7.0/bin/rake:23:in
load’
/opt/zammad/vendor/bundle/ruby/2.7.0/bin/rake:23:in <top (required)>' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli/exec.rb:58:in
load’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli/exec.rb:58:in kernel_load' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli/exec.rb:23:in
run’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli.rb:479:in exec' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/vendor/thor/lib/thor/command.rb:27:in
run’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in invoke_command' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/vendor/thor/lib/thor.rb:392:in
dispatch’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli.rb:31:in dispatch' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/vendor/thor/lib/thor/base.rb:485:in
start’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/cli.rb:25:in start' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/exe/bundle:49:in
block in <top (required)>’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/lib/bundler/friendly_errors.rb:103:in with_friendly_errors' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.33/exe/bundle:37:in
<top (required)>’
/opt/zammad/bin/bundle:121:in load' /opt/zammad/bin/bundle:121:in
