I have been writing a ruby script to assist our migration from OTRS (So that when I import the last OTRS diff I can run the script to set up our groups and roles and user permissions)
I expect for any user changes or changes to groups and roles to persist, e.g:
me = User.find_by(email:"my@email.com")
me.update_attributes(login:"floyd",roles:[Role.find_by(name:"Admin")])
After this I reindex elasticsearch.
I run this command and it works temporarily, but after about 5 minutes the scheduler container performs some searchindex jobs and changes everything back completely.
I also destroyed some groups and they reappeared after the same period.
Even if I stop the scheduler container, make changes and finally reindex elasticsearch before starting the scheduler again, as soon as the scheduler starts it will erase my changes. How can I avoid this?
Apart from installing via Docker-Compose, and making some user or group changes, I’m not sure.
You’re simply not saving your changes, that’s why the changes are not permanent. In fact the above change only applies to that one rails console session, not Zammad itself.
Thanks for the suggestion, what confuses me now is that there was a diff running (unsure why); I turned it off and all changes seem to be persistent now, without requiring a .save!. Is this expected? Will my changes revert without this .save! call? If so, when will they revert?
The information stored and changed in me variable will be consistent during the console runtime. It will be cleared after. So if you call me the object information being returned is always the value you modified it to.
me.save! actually submits these changes to the database which makes it persistent.
You can cross check that by updating me with any value you want and then run the rails command (e.g. for finding the user you updated) without using the me variable. You should see the differences then.
If you do not me.save! your changes, as soon as you close the console session, the variable is being freed / destroyed and thus your changes are lost.
You should also be able to cross check this via the ui by the way. If you update the note without .save!, you shouldn’t see it in the web interface (no matter how hard and often you hit “refresh”).
I think I understand, but I am a bit confused. You said that loading a user into a variable me as follows:
me = User.find_by(login: "my@email.com")
me.update_attributes(login: "me")
will not update the web interface. However, it seems that just did change the interface?? I was able to login with my usual password and “me” as the username.
