- Used Zammad version: 6.5.2-1767084541.f701ab19.noble
- Operating system: Ubuntu 24.04.3 LTS
- Browser + version: different
i’m very new on zammad and do much try & error things for learning on a test system. Now my problem is, that the style of the default e-mails is very small. so i want change the letter size. i don’t find anything in the admin gui. i just found in /opt/zammad/app/views/ …. different files, where i can change the text and variables.
So my questions are.
- Is that the normal and correct way to change text in the language template files, or will they be overwritten at the next update?
- Where can i change the style of the outgoing mails?
kind regards.
H-BLOGX
