Question on certificates
  • Used Zammad version: 6.3.1
  • Operating system: Debian 12
  • Browser + version: Chrome
In on of the last versions the possibility was introtuced to import certificates into Zammad (Settings, Security, SSL Certificates).
I use Apache as Webserver and uploaded my 3 cert-files to:
/etc/apache2/ssl (ca, crt and key)
I configured the certs in /etc/apache2/sites-available/zammad.conf:
<VirtualHost *:443>
SSLCertificateFile /etc/apache2/ssl/mycert.crt.pem
SSLCertificateKeyFile /etc/apache2/ssl/mycert.key.pem
SSLCertificateChainFile /etc/apache2/ssl/mycert.ca.pem
My question is:
Has the Zammad SSL menu something to do with the webserver or do I still have to change the certificates on the server itself?
The ssl certificate functionality within Zammad has nothing to do with certificates that are used outside of the Zammad application scope (as mentioned in our documentation: SSL Certificates — Zammad Admin Documentation documentation)
This means: Your webserver ssl certificates still belong on the server you’re using and shall not lay in Zammad directly. There’s no good reason to do that.
Thank you for the fast answer!
