I would like to see a ldap integration extended.
Link Avatar from Zammad to LDAP field called thumbnailPhoto
Also is there any chance you could add to Scheduler an option “every X seconds/minutes/hours”?
At the moment the lowest possible value is ‘every 10 minutes’.
Thank you.
