- Used Zammad version: 5.4.0
- Used Zammad installation type: docker-compose with official compose file from here
- Operating system: Fedora 37
- Browser + version: Firefox 100+
- I can successfully setup Zammad with the sendgrid smtp server
- While trying to setting up Zammad with an sendgrid smtp, i get the following error message:
550 The from address does not match a verified Sender Identity. Mail cannot be sent until this error is resolved. Visit https://sendgrid.com/docs/for-developers/sending-email/sender-identity/ to see the Sender Identity requirements
Notice: Sendgrid requires me to use apikey as the user name for the SMTP.
- Create an API key in sendgrid
- Run the zammad setup wizard
- Enter the created credentials into the E-Mail smtp dialog
i’m trying to setup Zammad on my home server for evaluation purposes. I’m stuck at the smtp setup as described above. I know, that this is actually a SMTP error. I guess, that i would need to use something like support@mydomain.com as the user, so Zammad knows which sender E-Mail to use, right?
Unfortunately with sendgrid i can only use apikey as the username, which is why (i think) i get the error. Is there any way to circumvent the Wizard dialog?
When i choose to use sendmail i get the error message:
No such file or directory - /usr/sbin/sendmail
The reason i am using a service like Sendgrid is, that i’m using Zammad on my homeserver with dynamic DNS. If i would use any regular SMTP (like gmail, yahoo etc.) it would be blocked quite fast.
Edit: Added reason i’m using sendgrid
